Clutch issues
james lethborg
I have an 05 TE 450. When riding a while ago my clutch started to fAil after Riding for a while. After Letting it cool down for a while it started working again. I have since changed clutch fluid and engine oil. Same problem occurred yesterday on a ride. Any ideas on what could be causing the problem. Just thought I'd ask on here before paying for someone to tell me. Cheers
First question: Do you have clutch fluid in the res after your clutch fades? If not, then you most likely need a new o-ring for the slave or your slave may be worn out. I ran a 7602 piston/ring set up for a while, but eventually ended up replacing the slave cylinder as well. Do a search for 7602, they should have what you need and are great people to deal with. I found that a new stock slave cylinder combined with the 7602 piston/ ring to be the best option. Make sure you have all the air out of the line as well. Push the fluid in from the bottom using a syringe and some carb vent tube, much like bleeding the brake line. Good luck!
i havent check the resevoir once it fades. i did bleed the clutch fluid and so all air should be gone from the system. so you suggest when replacing fluid. do it from the release valve not filling the resevior and pumping it through?
I have bled mine both ways. Either one works.
