Clutch Issue 2011 310
Mikenc
After about 10 – 15 min of riding today the clutch stopped working. The clutch would not disengage the engine and there was no tension on the clutch lever. I let the bike cool down it worked fine for 10 min and then the samething happened - tried again samething. Any ideas on problem would be greatly appreciated.
Thanks
Michael
Thanks. I flushed the fluid and road the bike for 20 min and the clutch seemed to be woking fine. The clutch fluid was very ugly. I did not think you needed to change the clutch fluid tha often. I will go riding this weekend and see how it hold up.
I had a 2009 TXC 250 that exhibited the same symptoms. I flushed the fluid and it came out milky... like it was contaminated from day one. After flushing, I had no problems.
I am glad it is better make sure you have a good look at the seal around the top of the master cylinder as it needs to seal off completely other wise water will get in.
