Clutch Engagement on 310R
Tugsy
Any idea how to make the clutch engagement start earlier. Right now it wont engage till very end of the throw. Adjusting the red dial does nothing but change position of the lever to the bar. Thoughts?
you need to troubleshoot. Bleeding is a simple good start. look for wear on the pushrod ends and bearings of the pushrod. Plate measurements need to be correct, check for warped plates, springs need to be good, master and slave cylinder need to be solid with zero bypass. there can be no off the cuff magic to tell you why. fact is that there seems to be too much free play/space. you must do a step by step inspection analysis to find the issue.
