moseleykmc
Folks, I am trying to eliminate slight clutch drag that prohibits selecting neutral at idle. I have checked and eliminated the below causes:
Oil viscosity too thick- now have ATF
Warped plates- have new fiber and steels replacing alloys- the pack thickness is within range
Worn actuator- the half round is in good shape
Adjustment- all adjustments are correct, and all 5 rod pieces are present.
I have not yet checked the release plate movement for level with a feeler gauge yet, am trying to locate new lock tabs before bending the old ones again. The are 3 threads showing in each nut now. I assume that if the plate is not releasing in a level manner that could cause drag?
I also have the round ends of both outer clutch rods facing outboard- one on the half moon actuator and one on the clutch release plate. Please let me know if the clutch rods are facing wrong and should have the flat ends outboard.
I did not look at the how far the clutch basket is pressed on the output shaft so as to be level with the bushing sleeve. As there are to slight grooves scratched into the clutch cover from the locking rings, could thee whole assembly be too far outboard as a result?
Any input would be appreciated!
