RickyDZero
I am putting my 86 xc 400 back together and ran into this problem. I put an 87 Transmission in
it, which means the shaft has a nut rather than the clip the 86 shaft had. Also the clutch basket
has 6 bolts instead of 5. I got the 87 clutch basket in it which is bigger than the 86 unit. The problem is the clutch basket hits the clutch cover. I did not think the clutch cover would be different from 86 to 87 am I wrong? Do they make the smaller 5 bolt for the 87.
