Clutch arm spec
The ML frame service manual says 9mm - 13mm. Check out the PDF for reference.
Nothing like a clutch that doesn't work right to ruin an otherwise fun day of riding.
Funny story....
Except it wasn't that funny....
Looking for Manual is a good call. So is following it.
looong way to go, just want clear free play without the cable on it...as George says 3 - 5 mm
George is right. When you have a hard time finding neutral this center clutch rod and lever have too much play in it. I set mine tight like George says. I set it at 1/8" play. Just enough space for room to expand when it gets hot and still properly function.
I purchased my second running 83/430wr for $150. The guy had the clutch cover off and clutch apart. He said it needed a clutch. I said nothing. The clutch looked new. The rod and lever needed adjustment.
If your clutch is ever slipping take a minute and revolve the clutch cable from the clutch lever and check for play. If no play the rod needs to be shortened.
