Clutch and brake levers
richard kersten
Can you replace the clutch and brake lever with any after market one or do the have to be husky specific , have the 12 te 310. Thanks
I got the SUNLINE "unbreakable" levers at the , dare I say it KTM dealer. the 310 has brembo clutch & brake .
same as some ktm models.
Stockies can take a pretty hard hit you know. I have them just tight enough to flick up on the bars in the event of a hard fall. before they are impacted I have by bark busters metal bar about half an inch below the levers so there is a double protection.
You would have to confirm but I believe at least the brake side is the same brembo lever used on many KTMs. I haven't checked the clutch lever yet but being that both brands use Brembo I bet there is a ktm and aftermarket equivalent that will work. I believe KTM changed the levers a bit for 2014 so those would likely not work.
