Dangermouse449
Any ideas ?
Ps, bike goes great, just wondering whether it's worth the time trail side to try different settings ?
Yes, it's definitely worth carrying a screwdriver & fiddling on the trails.
A suspension tuner listed this method in an article I read recently. It is time consuming, but methodical.
The best way is to find a trail that loops back to a central point that has a mix of terrain you run over normally.
Count the clicks 'in' all the way & record the settings you have now before you go changing it all. (In case you want to start over)
Then back them out past the original setting by 5 or 6 clicks & ride your loop, see how it feels to you.
Starting with the rebound setting, & go in a couple of clicks then try again. Keep doing this until you feel it getting worse.
Then repeat the process with the compression settings, a couple of clicks at a time.
Record what worked best to use later if you change settings for some reason.
Having the original TE or TXC setting really is of no use when you will likely move away from standard for how & where you ride.
Hope that helps.
