Check Valve setting on 2009 TXC
rudyunknown
Hi Guys
Need direction for the instructions for the valve check on the 2009 TXC, does this follow the xlite valve check or the older motors.
I am going to change the coolant impellar, so i was thinking after getting that done might check the vales too.
Thanks
Rudy
what are the other parts that requires changing when i do the valve check....like any gaskets etc....this is the first time i am doing this so all these questions.
thanks
rudy
thanks
rudy
None really, the top cover has a rubber gasket built in, no ther consumables I can think of.
Be careful tightening the top cover bolts, just get them snug and stop.
I have just purchased a torque wrench and will tighten to spec...question though....loctite bolts?
