Cheap Fuel Pumps te 310
zambo
I bought one of these off the net it worked well but beware of the ones with the straight barb on the outlet of the pump this is the one I bought. No matter how tight I did the clamp up I could still pull it off if you consider it has to support fuel filter its not good enough . I cannot trust it so now it is only a spare in the bumbag.
I don,t want to be stuck miles away from anywhere with this problem. If anyone has any ideas to get the hose on tight let us know.
I cut a straight section of the standard plastic line, boiled it in water for couple of mins and slipped it over the barb on fuel pump. the increase in size although small is enough to make hose tight on barb. advisable to use a good quality efi hose clamp not a worm drive type. no probs so far for me
I used good efi clamps but did not use gates hose this may be my problem. The pump worked well but I just could not trust the fit on the short straight barb. Same hose same clamps on original pump and could not pull it off.
