Changing front sprocket TE511
Mikepod
I have looked in the Workshop manual and the parts list and I can't find any decent description on the steps to change the front sprocket.
Can anyone help a mechanic wanna be?
Put bike on stable centerstand, Remove lower shock bolt, removed covers over swingarm pivots, removed swingarm pivot bolts, run chain off rear sprocket, slide swingarm back, remove front sprocket and reverse to reassemble, readjust chain...you can probably go down or up one tooth on front with the stock chain.
Its easier than most conventional bikes.
