Bryan M
replaced the factory chain with a did oring chain on my 13 tc449. bike has been on five or six 45 mile loops. Was in the garage the other day for an oil change and it was checking around the bike and i noticed the chain was slightly loose, so i tightened it up a bit. I spun the wheel with a bike on the stand and the first thing it did was catch the chain masterlink clip in the rear slider and rip it off. looked like the masterlink had seen better days and was slightly bent so i replaced it with another DID oring chain masterlink with almost same dimensions (pin length is half a mm off, DID doesnt make the chain i have on the bike anymore). Chain is still catching in the slider really bad at the masterlink. Im confused, i rode the bike over 300 miles with this chain, and everything was fine until i tightened it up slightly, and torqued the rear wheel axle boly to 100 ft lbs. Alignment is confirmed spot on by the adjusters, although it doesnt seem centered in the slider. Ideas on what happened??
