Chain Guide for 50 tooth rear sprocket
ADVRacer
I'm still in the process of getting my brand new 2012 TE310 set up and frankly, it's been a nightmare. Here's my latest and issue. I just swapped out the stock 40-tooth rear sprocket with the 50-tooth sprocket. The stock chain guide sits too far back and to high for the 50-tooth sprocket. What's everyone else doing to solve this issue?
I added 3 rivet on links to mine. Guide works fine. Check out BRP or the one ZipTy sells if you don't like the stock one but it should be fine. I think MBR nailed it. Your wheel/axle is prolly too far forward in the adjuster crowding the chain guide.
Thanks for the advice. I moved the adjuster almost completely to the end and modified the guide by chopping off the lower part that extends out. I added one more link to make it work. The guide still looks a little close but I'll take your advice and work with it. Thanks again.
