wallycycle
I installed a GPR steering stabilizer on my '08 SM610 last year. Very pleased with the unit and has "calmed" down the front. That along with the fork compression adjusters from LT-Racing has transformed the front end.
A caution though regarding the GPR install. I recently had the 20A lighting fuse blow a few times. After the second time I figured it wasn't an anomaly. I removed the headlamp assembly and noticed one of the three wires coming out of the headlamp connector was worn through and shorting on the GPR headstock collar. There is virtually no clearance between this connector on the backside of the headlamp and the GPR collar that goes around the headstock. They are in line adjacent to each other. The position of the headlamp fairing is fixed by the two "fingers" on top and the screw which comes up through the front fender from below. I have since wrapped the connector with 3M fuse tape which is quite stout and hope this will prevent further abrasion through the insulation. Moving the headlamp/fairing assembly further forward would be the ideal fix but its position is fixed from above and below. The relative position of the collar is also fixed.
