case saver???
To protect it from the ground or from the shifter/brake lever?
I'll say the Hyde polymer skid plate saved my left side case in a 50mph lowside, but it did get a scratch from the shifter.
A case saver is designed to save the case if the chain breaks
7602racing is what you want if that's what you're looking for.
Ah, I've heard the formed, stick-on metal plates that go between the case and the pedals called case savers too, which is what I was thinking of for some reason. The original steel case saver on the 630's is snug in there, not a whole lotta room for something bigger without going down to a 14t :thinking:
That's right, the 630 has a bit of metal stock. The 610 just comes with a plastic cover, weak.
