Carter vent leaking oil
Abelma
Hi, I would like to know if somebody has the same issue as me. I have an 83 CR500 and when I ride in deep sand and highs revs a lot of time, oil from the carter is going up into the vent tube and oil coming out. In normal tracks, where I dont rev too much too much time, is not a problem. Thanks
how much oil are you running in transmission?
how thick is the oil?
it seems if the oil is too thick or too high in the transmission in can overflow..
inspect your seals, you can do a 2T crankcase pressure test- seal exhaust and intake to do a crank seal pressure check- you can find this technique on the intertube.
she may be having a crank seal leak - crankcase pressure past the shaft seal into the gearbox pressurizing the gearbox, but many time these work both ways so also you get gearbox oil sucking into the bottom end causing extra oil in the burn/bottom end mix.
BTW for those here that don't know it the Carter=Crankcase in Euro speak.
try going to ATF - F for the gearbox. check its the correct amount. if your carter side gbox seal is gone, you will look like a cruise missile on full boost....a smoke trail that will smell like gearbox oil. ive seen this on cold mornings with some oils, they aerate but until they warm right up, they cant bubble out and the oil goes up the pipe for awhile.
