RTFliferide
Trying to get a '85 250wr to run clean. Water cooled, last of the twin shocks. Issues are, sometimes hard to start, Kickback on lever 30% of time, abrupt stop of lever 1/2 way thru 10% of time, Bad bog in initial 1/4 of throttle, then bike takes off like a rocket ! also leaves an exhaust trail like a rocket. Air filter ok but sealing flange starting to go bad, have one on order. filter to carb boot is good, carb to reed manifold is good, reeds are good. Lots of spooge coming out pipe, cleaned packing out twice. New petcock, float bowl set right, new float needle & seat. Mikuni 38mm- innards as received- main 410- pilot 35- needle 6dh20- needle seat 166 p8- slide 2.5- float needle seat 3.3. - needle clip 4 down. Appreciate any carb jetting or ignition timming advice, This one's giving me fits, Kicking leg starts to hurt just looking at it .
