have a 2009 SMR510
for whatever reason I cant set my idle higher than 1650-1700 on my 2009 SMR 510, even with the idle screw cranked all the way down. Idle is rough and it is sometimes stalling.
Now I did spray the rubber intake boot with starter fluid that connects the airbox to the back of the throttlebody, and the rps shot up so that is leaking around the ring clamp. Would this be something that would mess with my idle? It is not the boot connecting to the engine (this one didnt leak).
I recently rebuild the top end and I double checked the cam timing - everything is good. However when doing the top end I noticed when setting the main cam timing gear the double dots could line up at two potential TDC points ... when the piston just about reached the top and when the piston was just starting to go back down. I set it when the piston just reaching top - was this correct?
Thanks
Thanks
