Cam chain tension?
Flynn
Hi, I'm replacing the cam chain on my new shape 610 soon.
The bike has a manual tensioner instead of the standard auto one, which my old one had.
I am of the impression that a new cam chain doesn't need any tension on it (from the tensioner) it at all, is that correct?
A cam chain, new or old will need some tension on it. You can see that yourself when you install the new cc with out the mcct being installed, there will be some slack you need to get out. I would install the new cc, then the mcct before you put the fly wheel back on. You can then see/feel what needs to be done, and get it close, then fine tune it with the engine running.
Good idea re leaving the flywheel off, I hadn't thought of doing it that way. I guess I will just have to feel for the "right" tension. I'm guessing loose is better than tight though right? On my old bike the tensioning blade broke off it's mounting so the chain had no tension on it (unbeknown to me) but still didn't skip.
