J-train
I just purchased a used TE510 from a Texas resident in the state of CA. Should have not been an issue with the CA dmv. The 07 TE510 is fully streetable and 50 state EPA compliant. I went to do the paperwork at the DMV and all was fine until the required vehicle vin verificatiion required on out of state vehicles being registered for the first time in CA, if they are a 06 or newer and have less than 7500 miles. Well the vin check went fine, the Cal/fed Emmsions label checked out fine, but..........there is also a federal safety standard certification label on the rear of the front fender. Being 6 years old and exposed to the engine heat/elemets etc, the label is almost completely illegible. You can jsut barely read the bottom lie where it says this vehicle complies with all federal safety requirments in place at time of manufacture, but thats it, the vin, build date etc is pretty bad shape. To any logical human bieng this would nto be an issue, good vin, goood epa sticker, a safety cert tag that is definatey there and one could easily tell it's legit. But alas CA rats seem to get a kick out of denying you anything even if it's a legit 50 state bike. Question is what now, how do I prove that the bike is good to go? I called Husky and they were no help as in 07 MV onwned Husy. MV's contact is in Italy, so they I am sure will have no clue.
