Bullet Proof rear brake set up (my side of the story)
robertaccio
EBC Red carbon pads, Motul RBF660, Slavens caliper heat sink, ZipTy reservoir extender, ZipTy brake pedal stop, Brake Snake cable, OEM brake line, OEM brake pedal, MotoSportz disc guard, safety wired brake pin clip, OEM rotor and Caliper.
We all have our setup evolved from years of experiences (for me mostly evolved from failures and issues) This is the set up that works for me in my world.
Cool setup. I'm guessing brake fade is a non issue now? Is that a stock size rear rotor? It looks huge in the picture.
Nice setup. I have found the carbon pads are horrible in the wet though. Just food for though for us wet riders.
bike is looking real nice.
Few questions. Why would you extend the resevoir? Does it give more feel with the rear brake? Also, whats the purpose of a rear brake stop? What is the slavens caliper heat sink for?
Sorry, as I've mentioned before, I'm much more of a street rider. I'll check into the Slavens part on his website. I found his trail head blog a couple months ago and that guy's shop is about 10 minutes away (he really seems to like the orange bikes though for some reason lol).
DUDE that rocks! More then once Iv'e burnt inro a corner (I do not use my front brake at all!) and presto No brakes oh shi----! Ride a 150 Husky and since it weighs so much less you might not quite need that much of a bullet proof setup**************************************** But regardless I LIKE IT!
Few questions. Why would you extend the resevoir? Added fluid volume for more heat dissipation
Does it give more feel with the rear brake? No change in feel at all, its just more fluid volume.
Also, whats the purpose of a rear brake stop? Bling all bling it's the same as oem snail type adjuster, it's just red anodized (my OEM one got more and more dented from brake pedal hits. (ZipTy also has a more stout version but requires some mod)
What is the slavens caliper heat sink for? To help dissipate heat from the rear caliper/fluid.
All these parts are there to prevent rear brake fade which has cost me in time loss and crashes in at least 2 races/rides, once very bad at the Tecate Hare Scrambles in an ugly downhill rocky river bed section with no rear brake it really sucked using only the gear down clutch braking and front brake. I vowed never again.
