Broken Horn
mikebru
Anybody have a horn they are willing to part with?
I have a 2005 TE 450 I bought used. Horn never worked and I never needed inspection. Would like to have one, though, for when I get lost.
Checked the horn out and one of the tabs for the connector was broken off.
Can I solder something on? I don't have the broken tab. Thanks.
Almost any old 12 volt horn off of any bike will work. If you have a salvage yard nearby, you should be able to find something cheap that will work.
you can buy new horns for under 10$ from almost any major suppiers here's a cheap one from RMATVMC $6.99 as an example- It just won't have the same mounting tab.
My 09TE450 has a mounting tab that bolts to the tripple tree pinch bolts. While being a novice-to-a-novice at air tactics, I broke the horn tab on a "old school" moto-x track. Didn't crash but every landing was probably less than smooth.:D
I just welded the tab, ground it smooth, painted it black and reinstalled. So you could weld on your old tab to the new one. Weld not solder. Riveting might work. Or make the new horn and tab work somehow...
