brake light and blinkers stopped
Stolenfant
Looped the bike hopping logs. Bent subframe extension, and cracked black plastic tailpiece housing tailamp, but no obvious wiring issues. However, brake lights don't illuminate, and blinkers don't blink. I swapped power leads on brake and tail lamp, and the both brake and tail lamp filaments work fine, so ground is good, housing is good. I'm taking bike on a long weekend group ride, and am almost out of diagnosis time. Are there any fuses or relays or reset techniques like the speedo reset I should try?
Insane wiring!!!
In frustration, I took a break to lube the chain. After the engine sputtered to life, the blinker started blinking! Brake lights worked too. Kill the engine, and blinkers and brake light stop. What the hell kind of wiring is that?
I'm not talking ignition switch on, I mean engine MUST be running!
BTW it's a TE610 2009
