bought another cr frame.
Bigbill
I picked up a silver cr frame the has the squared off rear no loop. They called it a '79 but I don't remember any 79's with the square rear with the two nylon plugs? They said it's a 390cr frame. I'm thinking it's a 1980 or newer like 81? Don't know the number yet it's not here. I purchased the swing arm and rear olins too.
Since I'm a class A machine builder, lead engineering tech and built the recoil shocks for the 155mm
Howitzer for the US army that were filled with 200lbs of nitrogen. I think I can rebuild the olins it's a thought right now. There isn't much I haven't worked on in my lifetime.
Warning, when working on the equipment that has these large giant shocks there filled with nitrogen. We lost a local man here when he tried to disassemble it without removing the gas first. This was an excavator on tracks. Know your equipment before you take it apart.
The national timber fellers association says ask yourself is what I'm about to do safe? It could save your life. Be safe do it right.
Probably an '80 or newer, but a '79 with the rear loop cut off and some plugs in it would look a lot like it. A way to tell besides the frame number is if it has the tabs for the '81-'82 side panels.
The only thing I can see in the picture is the swing arm has the large spring loaded chain tensioner. She has the twin olins with the hoses and gas cans. Plus you guys are right it's an
80's and needs the number plates. I scored. I took a chance.
The frame, the swing arm and the olin rear shocks aren't here yet. From the pics the rear frame is squared off with those two nylon plugs and she has the oval number plates. I believe it's a 1980 frame. It's the wide low seat I'm guessing.
