Bones
Alright. Some of you that have a Baja Design light and want a hi/lo beam. Well Boatman here has your ticket here in a brilliant kit that is a no brainer even for idiots like me.
Package arrived and I dove into it even though I did not have the time to finish the install that evening. Everything was nicely packed and instructions to boot.
Items included in the kit
BD Light taken apart and the first "ring" gets laid into place. Keep the BD gasket in place
Place the new Hella housing in place
Next place the second ring to the back of the light housing. Note the yellow dot at the top per instructions.
Add your bulb (sold separately), the rubber grommet and either a pig tail or you can use spade connectors and more or less make your own harness.
Almost there. Looks good.
Time for a
I decided to use my stock plug from the OEM light as I will never use that light again and if I do I will worry about that then. Few splices and it was time to button it up.
Here are a few pics. STOCK Husky Headlight (since I had it on the bike already
BD Light with Boatman's Conversion (Low Beam)
High Beam
Time for a
High Beam
