Blue wire to battery? + or -?
mokibear
I removed my battery to get our my shock several weeks ago, went to install the battery can't remember whether the blue wire attaches to the + or -. Wire comes from right side, just down from the fuses and what I assume is the voltage regulator?
On my 630, the blue wire goes from the plug that goes into the reg/rec to the top reg/rec mounting bolt.
so its grounded? The wiring diagram show it is a ground,, but for some reason it was grounded to the battery on mine. I will attach it to the frame. thanks
