Skoalman
I recently purchased an 83 Husky WR 250 (with an 82 engine) that had been sitting for nearly 3 years. The bike was clean and it started right up. One thing I did notice however, was that a half-dollared blob of oil had spurted from the vent tube when the owner started -- I figured that the crankcase had pressurized, and it was just expelling some some goo...After going through the bike, (NOTE: pulled the mag cover, it was bone dry, and the crank was tight!) I raced it 2 weeks later...Bike ran strong. I wasn't racing to win, just wanted to see whata the bike felt like. Well, I got it home, pressured washed all the muck and goo of the bike, and tried to restart the bike! -- It was a no-go. The air filter was a mess, the carb and fuel filter were putrid. Thought maybe I had contaminated gas, or sucked in some water somewhere -- it was a muddy, watery, but fun course.
Needless to say, I drained the tank, dissected and nearly sterilized the carb, drained the oil (came out very watery, but not grey or miky), put in a new freshly oiled filter, new plug, and even rejetted the bike...I finally got the bike to light, and I thought all was good. Well yesterday, I started to go through the bike to get ready for upcoming ISDTRR ride in Oct. The bike wouldn't start. Kicked nearly a bazillion times! Cleaned the carb, new plug, fresh gas, yadda, yadda, yadda...This time however, I pulled the pipe to the head for leaks and when I turned the pipe upside down, about half point of oil, water, gas or whatever it was poured out of the pipe.
Pulled the mag again...and there it was -- A BIG OL' PUDDLE OF OIL AT THE SIX O CLOCK POSITION IN THE MAG COVER!! I've gone through the engine and carb from soups to nuts over the past 2 days, and now believe that I have a CS leak. The bike is very hard to start and will only start if you have the throttle half way open -- it's sputters, pukes, and farts, and then there's abundance of smoke which makes my the front of my house look like you're at a CHEECH AND CHONG great American Weed Convention! And yes, there's a another puddle of oil in the Mag cover.
So what's the point of this soliloqy you ask? Well, all I want to know is do I have to split the cases to replace the MAG Side crank seal?
Also does anyone know any Husky engine rebuilders on the east coast?...I can do everything (top end rebuilds, set timing, susp rebuild etc...) else on this bike except for splitting the cases...
Thank you very much, and I now concede the floor...
Cheers..
John
Cheers..
John
