Bing 54 to a mikuni
irockmxer
Hello all-was wondering if anybody has successfully installed a mikuni on a 1979 WR250? I would like to know what jets you used etc. I would appreciate any info or person that would give me the correct settings etc. Thanks Café Husky
you must have got an odd ball 79 should have had a mikuni as OEM the specs arnt listed in DB 7/79 but they are there for the 1980 5/80 MJ 430 NJ R2 JN 6DH3 PJ 45 slide 2.0 this ought to be close mains likely rich
sounds like someone stole the mikuni off of it. either way, yes you are on the right track putting a mikuni back on.
thanks! I got a bunch of cylinders with carbs. some 360's 250's etc.. Wasn't sure what was what!! I did find a Mikuni, took it apart and it is what you said. Thanks for such a quick response....:cheers:
it ez u jus gotta remember which issue u need crazy the info that used to be in DB wish it was that way today
I bought a 1976 360 WR and plan on bringing it back to life. It had little to nothing for compression so I pulled the top end off and found that the ring was way gone but no carbon at all. Someone has put a after market mikuni 38mm carb on and didn't jet it. It was jetted way lean. I got a 1st over piston and ring, will the jetting 78 250cr be a good starting point? Any help or suggestion would be greatly app. as I'll have a lot of question before this resto is done. Thanks
well i looked thru all 12 77 issues and all i got is a 77 390amx witch was A 430M Q-8 NEEDLE IN THE 4TH AND A 45PJ SORRY NOT MUCH HELP:excuseme:
