Irocleis
Ok, so i basically wrecked into a retaining pond
lol... luckily i locked up the brakes and caused the bike to stall out before laying it down in the water so im 95% sure there is no internal damage due to the compression of water. When i got the bike out of the water i removed the air filter, layed the bike on its side and got as much water out as quickly as possible. towed the bike home I did not try and start it or kick it over. Now i drained all the oil, removed the air filter, took out the spark plug. i pushed down on the kicker a couple times to rotate the valve and get some more water out, i also sprayed some WD40 down into the head (through the park plug hole) and kicked it over a few more times just to prevent any rust from forming. My bike is in my garage with the oil plug and fill plug still removed and the spark plug still removed.
What do I do next??? just let it sit a couple days? should i flush the crank case out with anything? I'm open for all opinions and if anyone else has been in the same boat.
Thanks!
Thanks!
