Best Hour Meter Fix or Work-Around TE 310R
Trail Tech HourMeter and Tacho
No power required, just coil the sensor wire round the plug cap.
See what your engine's doing as you do it, then when you're done, you can see how long you've been doing it for!!
Mike
Hi Mike,
did you get the Trailtech tach/hour meter to work on the TE310R ? If so, where did you wind the lead?
I could not get it to work and eventually gave up.
Cheers
Ian
Yes, it works a treat!
I think I wound about 4 turns around the top of the plug (wouldn't work with any less). I started off with a few turns near the bottom (closest to the plug), but I couldn't get the top back on with the profile. As it was, it is a close fit - I secured the "loose" end of the wire with some duct tape. I fed the wire through the rubber grommet rather than just underneath it, in case it cut the wire. Setting it up was hit-and-miss as I didn't know if it had a wasted spark or not, and I can't remember what setting I had it on I'm afraid.
Mike
