Backfiring
crem55
Here's the story ..... 09 txc 250 riding it since 2010 never any problems. 2013 I did a 310 kit and rode it till a few weeks ago when it started backfiring a little bit. Took it out again and it got worse so I did a top end gasket and rings along with readjusting valves that where still in spec. I cleaned the carb twice and change the air filter. Its still doing it. My question is does a 09 te 310 FI have the same electronics? Just want to try swapping thing to check before throw the thing off a cliff.
Maybe pull out the fuel pump and make sure the filter and hoses are not leaking too.
Might be a good time to change the fuel filter.
I just replaced the exhaust gaskets and to check the intake boot I buttered it up with RTV silicone.
well, you didn't indicate if the "butter" helped... so I'm guessing no? btw, the standard vacuum leak test is a quick, discrete spray of carb cleaner in the suspected area while the bike is running. an slight increase in rpm's indicates a leak. be cognizant of where the closest fire extinguisher is.
good luck.
You can also use a propane torch. Just use the tip of the torch around the boot without firing the torch up. What kind of plug is in the side of the head where the air injection is supposed to go? I'm not sure if the TC/TCX used a brass nipple like the TE's did.
No it didn't it's still doing it. So it's not the boot. I did spray the carb cleaner starting at one side of the carb at the bottom and worked my way up. It's somewhere on the right side top. It's driving me nut. So I took off the slide cover and put RTV around that gasket , let it dry and tried it today. Still doing it****************************************! Going to order a rebuild kit and go from there. Maybe I have a small crack in the carb or ......... I'll keep everyone posted. My clubs Enduro is this weekend so ill be arrowing with the TE. Had to take all my computer and GPS off the TXC and Put it on the TE. WHAT A P.I.T.A
Not sure I will look tomorrow
