Axle sliders
Can't say for sure, but the axle interface seems to be shaped similar to the ones I bought from Motostrano (that are no longer available).
Here they are before I had them modified to fit the TE:
The rears are a different design, so you don't have to remove the sliders to change a tire:
The interface point look very similar to the ones I built out of skateboard wheels. They look like the real deal at a decent price. Thats a good idea, rather than build a metal bushing and a delrin slider they have built them as a single delrin unit. Not as strong but probably plenty strong enough and much easier to build. With the through axle sliders you can adjust the chain without loosening them but they must be removed to change a tire, which is extremely simple of course. Cam.
i bought a set anyway.Front fitted a treat, rear r/h side protector needed a 2mm taking off to fit inside spindle.My threaded bar i have modified and welded a m8 nut to one end,makes it easier getting on and off.Well pleased.
