grouty
Auto Lover ...
I have noticed that since I have had my 390 Auto, every time I strip the box for inspection (every other ride). The 3rd and 4th gears on the main shaft are tight together. If I prise them apart with the special factory tool (two big screwdrivers
) then it rotates fine. When I come to inspect it again, they would have closed up and both rotate together.
Does anyone know what is worn ?
2nd and 3rd gear are ok, it's just 3rd and 4th. All the gears are a very tight fit on the respective stub shafts, and there is not much wear on the teflon bushes.
