stormer254
Bike 81 420 Auto.
I am trying to replace broken springs on clutch no.1, The manual just glibly says use a spring hook to fit spring. I am unable to even get the spring through it's centre hole, let alone stretch it over the brass weights! The only way I think it can be done is to remove the 32mm nut, pull the centre rotor of, disassemble the brass weights, fit springs , reassemble centre rotor and fit back on to crankshaft. Is this the correct way? If so where did the stories of replacing springs on the side of the trail come from?
I have searched previous threads an could find no specific advice.
All help and advice gratefully received
