motohio
I just got some ARC flex levers for my TC449. Im hoping that these will do the job of not breaking levers since I dont run full wrap "bark buster" type hand guards. Im having some issues mounting the clutch lever. The front brake lever (BR-103) went right on without any problems, and looked similar to the stock lever. When I tried to mount the clutch lever (CL-203) it doesnt seem to be the correct lever, it looks quite a bit different. Maybe you dont use the little ink pen type spring that keeps tension on the lever when not in use?
My question is has anyone put ARC levers on their 449? If so what model did you use?
Thanks in advance.
Kirk
Thanks in advance.
Kirk
