anyone have info on special parts ECU/short db killer for TE510?
bbcmat
The 2010 / 2011 Husky Special parts book has a ECU / short db killer combination for stock exhaust 2009 and 2010 twin cam bikes (310/450/510)
I searched and found a couple of users with the 310 kit - anyone use it in a 510 or know what changes are made to the ECU timing/fuel curves?
My main goal would to have a more aggressive timing curve (both initial and advance) for the 2000-5000 range. A Special Parts ECU could provide that if progammed for it.
THx!
MAT
Hmmm, dont know.
I think the DB killer may just be the spark arrester from the TXC?
The ECU is very different programming between the 310 and 510. They wont run with a 310 ECU on, tried it whilst investigating a problem.
I have been using a long Arrow on my 09 TE510 which pulls the revs out longer but it was to close to the airbox so I have reverted to the original.
Not much help am I... :excuseme:
Alec
The Db killer is not a spark arrester. It is a small pipe to choke down the exit of the can some. The Spark Arrester is a little screen piece that would replace the Db killer in the end of the pipe.
Thanks for the replies !
The 310 / 450 / 510 all have different part numbers for the kit.
The stock "soft" ignition curve will be easier on bearings than something else - I'll live with it.
MAT
