EricV
Hi gang. The piston of my clutch master cylinder is leaking- does anyone know the part # of the rebuild kit? The reason I ask is because there's a small KTM place nearby- they may have one and hoping to try tomorrow (long shot- they're kind of known for not having much.) Looks as though ours is a 9.5- is this correct? This shop isn't going to be helpful - I used 'em a couple of times a few years ago when I had my old RXC and they didn't seem to know squat...which is why I'd love to know the actual part number of the rebuild kit.
This winter maintenance thing isn't as enjoyable as hoped.
First it was the warped leaking tank, now this. Can't wait to ride it though- took care of the clutch washers (thanks Indy), re-greased head bearings (thankfully didn't need replacing), bleeding fluids, iridium plug (long overdue to make that change), lubing things, checking bolts (lots needed attention and loctiting), check/adj valves, etc.
Thanks all- CH is great.
First it was the warped leaking tank, now this. Can't wait to ride it though- took care of the clutch washers (thanks Indy), re-greased head bearings (thankfully didn't need replacing), bleeding fluids, iridium plug (long overdue to make that change), lubing things, checking bolts (lots needed attention and loctiting), check/adj valves, etc. Thanks all- CH is great.
