Houredout401
Looking for someone who has actually done this, no guesses please. When changing lower triple clamp bearings on Japanese bikes, I usually dremel off the cage then cut the race as much as I can then break it with a chisel. But to avoid cutting the spacers that are under the bearing in this husky triple I would like to press it out.
I assume it presses out from the bottom, ie press on the area where the circlip seats? I will of course support the triple close to the stem and heat the aluminum first. Getting it back on seems the scarier part as thread damage comes into play but I think I can fit something to the top of the stem to press on.
Is it worth it or should I just break out the dremel?
