another TE 510 to SM conversion question
ks9mm
Hi All,
so I am 90% (I think) done converting my TE to SM. Wheels at least are done. Still working on 320mm brakes set up...
so I am concerned about how to make Speedo working with different wheel size.. and also, my 320mm rotors will not have magnet for wheel speed sensor.. are there any solutions out there for this problem? I really would like to keep track of speed and milege
Thanks!!
I put a 320mm rotor on mine and used the sock pickup with a glued on magnet on the disc. I dont think you can change the wheel size on the stock speedo, it might be time for a Trailtech computer for you. The wheel size I'm using on my Trailtech is 1850mm which seems to be fairly accurate for 17's with stock tires.
will trailtech allow me for easy conversion when I change wheel size and gearing?
my dirt set up is 13/47 and Sumo is 15/42 + wheel size difference...
Yes, very simple to switch between wheel sizes.:thumbsup:
