Alternator output
mike54
I need to upgrade the lights for night rallying - I know the output of the alt at different revs but that's in watts. just wondering what kind of draw LEDs I can safely run? I'm looking at a 70 watt vision x light which i think would be about 6 amps (70/12volts). would the alternator be up to it? if so would it need a relay? I'm an electrical dunce and could use some help.
+1
I've run the Signal Dynamics voltage monitor on a few bikes, they're simple yet sophisticated, and give you all the info you need at a glance. Little green light off to the left, mount it out of your line of sight so it's not distracting at night.
Goes thru a self check at startup - flashes red 3x, yellow 3x, green 3x, and settles into the current voltagle condition. Self dims after 8 seconds.
I run my accessory pigtails (GPS, grip heater, etc) thru a Fuzeblock FZ-1 w/ it's relay tapped into the 5w running light, and my Gerbing coax direct to battery.
