Air filter Back fire screen/2012 txc310 Race ECU
mscott
Does any one remove that back fire screen to get more air flow? Also does any one know what the CO's settings on the race ECU, I was told it's 100 across the board but it shouldn't be if it is a race ECU and the TPS settings.
In my experience removal of the back fire screen resulted in a very noticable increase in hp and torque - suprisingly from lower mid-range all the way to top-end. My screen was partially obstructed by 1.5 years of gunk from air filter changes. Now the JDJetting settings feel pretty 'hot'. In other words leaner and no pop-stalls when yanking the throttle at lower rpm (happened occasionally before).
Thanks Mike B. Hey what are your settings on the JD jetting i have that to but just got iBeat and trying to sort out the ECU without the use of the JD jetting.
Veterans will tell you not to remove the screen. it's there to prevent a fire. to avoid years of gunk/buildup I remove and clean mine with each air filter cleaning. That way I can put the intake cover on and give the air box a good cleaning. Every time.
