2wheeler
I would like to soften/loosen up the forks a bit. Total noob when it comes to adjustable forks.
Would I be headed in the right direction with the following?
Compression (Lower Adjuster, Standard Setting 12 clicks) Turn capnut clockwise until closed.Turn counter-clockwise past standard setting to 16 clicks. Does the rubber pry out to reveal a hex?
Rebound (Top Adjuster, Standard Setting 08 clicks) Turn adjuster (C) clockwise until closed. Turn counter-clockwise past standard setting to 10 clicks.
