Adjust TE Fork: upside down fork and missing rear shock?
Nordic
My new 2012 TE 310 is the first bike that I have had in 30 years ( back when forks were mounted rightside up and there were two rear shocks! ;) Please forgive this incredibly basic question. I am trying to adjust the sag on this fork which is presently just slightly less rigid than a pair of 2x4s. The text and illustrations in the manual do not jibe (at least to my brain). They show txc and te but references to pictures seem wrong. I have adjusted the dampening using the center screws on the fork tops. But am uncertain where to adjust the sag.
Can anyone help? I am uses a formula posted here on the Cafe and that has worked really well in seting the rear shock.
Thankns in advance.
Scott
Don't think you can adjust the sag on dirtbike forks without pulling them apart and fiddling with the springs/spacers. Only external adjustment is for compression and rebound via the clickers top/bottom.
You would need to change the springs if you are wanting it to "sag" more. You can get a set from Race Tech for around $100. They cut them a little short so you can adjust preload with a washer stack. The differences in the fork drawings is because the TE has open chamber forks, and the TXC and TC have dual chamber forks.
