99 610 your opinion or advice
babalu24
Hi all 99 610 left kick grenaded the motor replaced all bearings new Conrad went with a 100
mm piston n jug from husky parts on eBay in the UK purchased a used head and tc 610 cam from bills in Oregon bike fires right up idles fine but smokes like chimney white put about 20 miles on it when I go to kick it over I hear a suction gurgling sound thought it was carb replaced needle and seat adjusted floats tuned fuel mixture n idle even dropped the needle one notch I’m not leaking any coolant so don’t think it’s a head gasket what is the gurgling sound from should I pull head and replace guides ?? Or rings I know I might of went a lil heavy on the file on the oil ring but not by much went with one tooth smaller front sprocket bike rips but is leaking a spot black like oil out exhaust heads and at the exhaust joints?? Any advice how long does it take for rings to seat ? Any input would be appreciated thanks , ENES
