93 Husky 350TE Oil filter?
Big Jim
Hi all,
having just purchased a 93, 350 TE i have a question as i'm new to all this but i was hoping someone could tell me how and where the oil filter is located and replaced, and if the oil needs to be bled thro the engine before cranking it over.
Look forward to your responce
BigJim
Oil filter is non-replacable screen that should be cleaned. You access it from behind the lower oil line banjo on right lower engine case. No bleeding needed. There is no oil pump, it uses a reed valve to move oil.
