'91 Suspension interchange
Will
My 1991 WXE610 has a tired suspension, along with other issues. I understand from Halls that seals for the forks are poor quality now and the WP shock has no replacement seals available for it. So, what would swap out? The forks are 50mm USD forks. I don't know length or length of shock.
Would Marzocchi forks from a 2000 or later bike work? Also, would a Showa or other later shock bolt up OK?
Hi Will, I have swapped a few forks on older huskies, sometimes you have to change the steering stem and bearings. It really just depends on what you are trying to do. The shock may be a little trickier depending on the position of the resivour and if it is a dropped down that will be harder.
