photoguy_43420
We are working on restoring a 86 400 WR. It has case rot in the crank case. Any tips on fixing this. I will have photos soon. Any tips would be appreciated.
Done this , works well.If the damage is non structural, you can use JB Weld or straight epoxy. If you break the gloss on JB Weld, you must seal it with epoxy. Both work well in oil or fuel vapor environments. You need to dremel out the corrosion prior to application.
Devcon is an industrial epoxy. You can get it at MSC Industrial and Lowes has Devcon epoxy. You want something better than the consumer grade at a retailer. I recommend https://www.amazon.com/Devcon-31345-Ton-Clear-Epoxy/dp/B0006O8QQ0
slick them over with epoxy . i have an 85 250cr and the cases looked just like that.
Did you use Devcon or some other epoxy?
i have some cases laying around PM me
The cases I received from 2premo were in awesome condition, I wouldn't waste too much time on those cases unless they were irreplaceable, but that's not the case, pardon the pun.
