76 wr 360 lights
Capt.38
Hey guys wanting to put a Preston Petty headlight and tail light set up on my 76 360 WR. I can run a battery only set up w/ 12 volt bulbs or if I use the lighting coil off the flywheel I think ill need a 6 volt lamp? Also if using the lighting coil wire do i need to run a voltage regulator or anything else to make this work? thanks for all your help.
If you run a 6 volt system, yes, use a regulator. Otherwise the first time you crank it on you will blow the headlight bulb. As far as I know the Preston Petty lights were 12 volt (may be wrong). They work fine on 6 volts, just not very bright. If you run a 12 volt bulb you can get away without a regulator.
