630 Tail Light Lens Replacement Options
Hokeewaa
Lost my tail light lens (2011 TE 630). The LED portion of the assembly is still there and functional. Dealer says he cannot order just the lens but must order the entire assembly for the tidy sum of $102. Ouch!:eek:
First, anyone know whether the dealer is correct about this or not? Second, if he is, does anyone have a line on an aftermarket unit that will interchange with the stock one? Open to suggestions.
Thanks,
Hokeewaa.
Yes your dealer is correct. Lens doesn't attach with screws, tailight is a complete and sealed assembly.
I would think you might even have a chance for a warranty claim on it unless broken off from an accident. Not having the lens to verify no impact will work against you though.
No suggestion for aftermarket other than verify light output from all angles first if possible before purchasing. The TE630 LED tailight has incredible light output. I've seen a couple aftermarket LED lights that are really poor. Straight behind and level you can see but off to the side or up or down and light output is practically non existant. I've warned and complained to a couple riding buddies about theirs. Neither are listening to me so honestly I'm waiting for the day they get rear ended as their aftermarket lights are that bad. $102 seems like cheap insurance to me.
_
Does the warranty cover race use? ;)
My rear brake light is stuck in the on position. Not sure if it is something wrong with the front brake lever, or the rear foot lever. Any suggestions on how to troubleshoot this?
Unplug one and then the other and see what happens.
If the front lever micro switch has come loose or is faulty will do this (ie if switch is open)
Thanks for the responses. Would be swell if it was a warranty-able item but since it was lost as a result of my tool bag whacking it during a race, it probably doesn't qualify. :thumbsup:
Ran across the UFO Plastics unit that fits the 2011 TE 250. Wondering if it would fit the TE630 as well. Anyone know if the 250 and 630 fenders are the same Husky part number?
