630 Lambda/o2 Delete......Noob needs help
duke_in_la
Bit the bullet and bought a used (1900) miles TE 630 for $6000 to good of a deal to pass up. I have read forums on this website about doing the Lambda delete, good info. I went ahead purchased the 2.2k ohm 1/4 resistor from Radio Shack as described did install bike is running killer, no more boggy throttle or jerkiness when cruising or between gears however, my idle won't go below 2850 rpm's. I have adjusted the idle all the way in and all the way out removed the air box completely just to make sure I had a good bead on the idle screw and the idle won't go up or down just stays at 2850. From what I have read is that the TPS now needs to be adjusted which is contrary to what others have experienced, others have done this simple mod adjusted their timing and bam! Good to go!.........Any feedback on what I have done incorrectly or what I need to do now? I take it I can't adjust the TPS witout some type of tuning device? I called my local Husky dealer yesterday and they said to bring my bike in and they will adjust it and tune for around $100 but if I can going to go that route kind of eliminates the DIY situation.......Any feedback from anyone will be appreciated...... I need to get my idle back down......Thanks in advace!
Idle increasing upon installation of a power-up kit is normal. The idle adjustment screw doing nothing is not normal.
As said above, throttle cable may need adjusting, or your TPS needs reset. The throttle cable you can do yourself, the TPS requires iBeat.
You can pay the dealer $100 every time you want to use their iBeat, or you can buy your own for about $300 from SEMCO Designs.
http://semcodesigns.com/Home_Page.html
Be advised, iBeat software will only run on a 32-bit Windows OS. If you have anything else, you'll have to get a cheapo computer, or use a virtual machine.
The fast idle cable (little trigger on the handlebar) needs to be adjusted since it is now causing your bike to run at high idle. Loosen the cable adjustment at the handlebar. You may have to adjust the cable at the FI unit if you can not get enough slack on the handlebar adjuster.
Thanks everyone! Checked the tension in the throttle cable and is not binding anywhere looks good. Definitely the idle screw - right behind the airbox to the right - check! I checked the "Hot Start" or "Fast Idle Cable"and sure enough once I adjusted this my idle went down immediately, got it idling at 1750 and bike is running sweet...........:cheers:
1650 is the owner's manual idle spec. You can turn it down a little more if you so desire.
